Hello All.
Been noticing an issue with installing the latest Cyper Power Power Panel V2.2.1 Software and Windows 10 2004.
Whether you use it on a system that has been updated to 2004 or a brand new build it seems you cannot install this version of the software and it locks the PC up bad and you have to restart then you need to use a 3rd Party utility to uninstall the software as the built in uninstaller will lock the PC up as well. I have contacted Cyber Power and am trying some older version to see how they do.
Has anyone else seen this behavior. I work mostly with Dell PCs.
Thanks for any Feedback
