I am using Win XP Pro SP 3.
I’ve been experiencing various problems with TBird 3 for several months and have been on the Mozilla fora finding many people having the same problems. I posted here a couple of weeks ago and got a bit of help but the “fix” has faded. Basically, after a period, I cannot delete in the Inbox or elsewhere. Often, Trash has many duplicates of what I have tried to delete but the e-mails remain in both the Inbox and Trash.
Similarly, sometimes I can move/drag files to other folders for storage but often get a message saying another operation is using the folder. Sometimes this goes on for sometime/permanently and other times only a few minutes. Sometimes restarting TBird helps, mostly not. Sometimes, clearing the cache and compacting helps and sometimes not. Often I have to leave TBird closed for a half-hour or so and do something else.
When I compact the Inbox, all the default column headings reappear and e-mail is sorted earliest to most recent. If I compact all folders but am not in Inbox, it remains with my choices. I’ve removed all but a few add-ons and increased my cache size to 300mB but this does not help. I’ve completely uninstalled TBird and cleaned out all references in my registry, then re-installed it. It then works for much longer but eventually it reverts to the problematic mode. As I said, there are many users with similar problems but the numbers are not large and no one from Mozilla answers many of the posts.
I am contemplating re-installing Windows XP totally. Does anyone recommend this or not? I am planning to migrate to Win 7 but the radical change in terminology and organization has made it difficult for me to become efficient in a short time. I have MS Office 2002 and could use Outlook 2002 but am worried about security and functionality, knowing Outlook has quirks also. Advice?
Thank you
