• Code Help – Plot Charts (2003)
    Dear Loungers,
    I need big help.
    I am given the above data. I need to save each row into a new file using the fund name (Column A), plot date (mmm-yy) against NAV line chart on a new Chart sheet (named “Chart”) and save each file.
    I have managed to record macro to do the above but I need help: The end date is fixed, in this case, July 2007. Some records have very early date (starting X-value), making the x-axis labels really messy. Is it possible to do some kind of codes to “force” the x-axis to have only a max of 6 labels but not less than 4 labels.
    Same goes to y-axis labels. There are some funds that go below 100. Is it possible to force the y-axis start value to be closest to the minimum value (round down and no decimal place) and the end value to be closest to the maximum value (round up and no decimal place). I also need to “force” the number of gridlines to have a max of 6 lines but not less than 4 lines.
    Thank you very much in advance. Having this will save me nights of manually opening each files and adjusting the axes.
    Regards
    Rid
    • #1075513
      The workbook you attached doesn’t include the code you already have. It would be useful to see the macro, so that we know how exactly you create each chart.
      • #1075565
        Thanks Hans,
        Below are the lines of codes that were mostly “recorded”. I am still trying to put everything together and make them do: create a new XLS file from each record, transpose the data (column A is now the dates, column B is the NAV data), plot the charts, fix those labels issues and save the files. All with a click of button. Can help?
        Sub CopyTranspose()
        Sheets(“NAV”).Select
        Sheets(“NAV”).Move
        Rows(“2:2”).Select
        Selection.Delete Shift:=xlUp
        Rows(“1:2″).Select
        Selection.Copy
        Sheets.Add
        Selection.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
        False, Transpose:=True
        Cells.Find(What:=”100”, After:=ActiveCell, LookIn:=xlFormulas, LookAt:= _
        xlWhole, SearchOrder:=xlByRows, SearchDirection:=xlNext, MatchCase:=False _
        , SearchFormat:=False).Activate
        Sub PlotLineChart()
        Dim myLineChart As Chart
        Dim dBeginDate As Date
        Dim dEndDate As Date
        Dim intMonths As Integer
        Const strTargetChartPath = “D:NotProcessed”
        Range(“B1”).Select
        newFileName = Selection.Cells.Value
        newFileName = strTargetChartPath & newFileName
        ActiveWorkbook.SaveAs Filename:=newFileName
        Range(“B1”).Select
        FinalPlotRow = Range(“B65536”).End(xlUp).Row
        FinalPlotCell = “A1”
        CompleteBlock = “B” & FinalPlotRow & “:A1”
        Range(CompleteBlock).Name = “AreaToPlot”
        MinimumValue = Application.Min(Range(“B:B”))
        MinimumValue = Application.RoundDown(MinimumValue, -1)
        MaximumValue = Application.Max(Range(“B:B”))
        MaximumValue = Application.RoundUp(MaximumValue, -1)
        MajorUnitValue = Application.Even(Application.RoundDown((MaximumValue – MinimumValue) / 4, 0))
        ‘ Beginning date.
        Range(“B1”).Select
        FinalRow = Range(“B65536”).End(xlUp).Row
        FinalCell = “A” & FinalRow
        dBeginDate = DateValue(Range(FinalCell))
        ‘ Ending Date.
        dEndDate = DateValue(“31/7/2007”)
        ‘ Calculate number of months between dates.
        intMonths = ((Year(dEndDate) – Year(dBeginDate)) * 12) + _
        Month(dEndDate) – Month(dBeginDate)
        ‘ Display number of months.
        NumberOfMonthValue = Application.RoundDown(Str$(intMonths) / 5, 0)
        If NumberOfMonthValue <= 0 Then
        NumberOfMonthValue = 1
        Set SourceData = ActiveSheet.Range("AreaToPlot")
        Set myLineChart = Charts.Add
        With myLineChart
        .ChartType = xlLine
        .SetSourceData Source:=SourceData, PlotBy:=xlColumns
        .HasLegend = False
        .Location Where:=xlLocationAsNewSheet
        .HasTitle = False
        End With
        ActiveChart.Axes(xlCategory).Select
        With ActiveChart.Axes(xlCategory)
        .MinimumScaleIsAuto = True
        .MaximumScaleIsAuto = True
        .BaseUnitIsAuto = True
        .MajorUnit = NumberOfMonthValue
        .MajorUnitScale = xlMonths
        .MinorUnitIsAuto = True
        .Crosses = xlAutomatic
        .AxisBetweenCategories = False
        .ReversePlotOrder = False
        End With
        With ActiveChart.Axes(xlValue)
        .MinimumScale = MinimumValue
        .MajorUnit = MajorUnitValue
        .ScaleType = xlLinear
        .DisplayUnit = xlNone
        End With
        Sheets("Chart1").Select
        Sheets("Chart1").Name = "Chart"
        Sheets("Sheet1").Select
        Sheets("Sheet1").Name = "Data"
        Sheets("Chart").Select
        ActiveWorkbook.Save
        ActiveWorkbook.Close
        Thank you in advance.
        • #1075635
          Try the attached version of the code. I streamlined your code a bit.
    Reply To: Code Help – Plot Charts (2003)
