• Code help for Option Group (Excel 2000)
    Home » Forums » AskWoody support » Productivity software by function » MS Excel and spreadsheet help » Code help for Option Group (Excel 2000)
    I found some code on the web to create a survey form.
    I modified it to create the option group that I want. In this case it makes a group in 3 rows
    The problem is that instead of the group in each row linking to the cell next to it, they all link to the same cell
    and the totals accumulate.
    Sub SetupSurveyForm()
    'code written by Dave Peterson 2005-10-27
    'creates a survey form with option buttons
      Dim grpBox As GroupBox
      Dim optBtn As OptionButton
      Dim maxBtns As Long
      Dim myCell As Range
      Dim myRange As Range
      Dim wks As Worksheet
      Dim iCtr As Long
      Dim FirstOptBtnCell As Range
      Dim NumberOfQuestions As Long
     ' Dim myBorders As Variant
    '  myBorders = Array(xlEdgeLeft, xlEdgeTop, xlEdgeBottom, xlEdgeRight, _
                               xlInsideVertical, xlInsideHorizontal)
      maxBtns = 3
      NumberOfQuestions = 3
      Set wks = ActiveSheet
      With wks
        Set FirstOptBtnCell = .Range("c2")
        .Range("a:i").Clear
       ' With FirstOptBtnCell.Offset(-1, -1).Resize(1, maxBtns + 1)
       '     .Value = Array("q", "Sales", "Service", "Sales Engineer")
       '     .Orientation = 90
       '     .HorizontalAlignment = xlCenter
       ' End With
        Set myRange = FirstOptBtnCell.Resize(NumberOfQuestions, 1) 'c2:questions + 1
     '   With myRange.Offset(0, -1)
     '       .Formula = "=row()-" & myRange.Row - 1
     '       .Value = .Value
     '   End With
     '   myRange.Offset(0, -3).Value = 1
        'With myRange.Offset(0, -4)
        '  .FormulaR1C1 = "=rc[1]*rc[2]"
        'End With
        '.Range("a1").Formula = "=sum(A2:A" & NumberOfQuestions + 1 & ")"
       ' With myRange.Offset(0, -4).Resize(, 4)
       '   For iCtr = LBound(myBorders) To UBound(myBorders)
       '     With .Borders(myBorders(iCtr))
       '       .LineStyle = xlContinuous
       '       .Weight = xlThin
       '       .ColorIndex = xlAutomatic
       '     End With
       '   Next iCtr
       '   .VerticalAlignment = xlCenter
       ' End With
    'myRange.Activate
        myRange.EntireRow.RowHeight = 28
        'myRange.Resize(, maxBtns).EntireColumn.ColumnWidth = 4
        myRange.EntireColumn.ColumnWidth = 32
        'clean up existing junk
        .GroupBoxes.Delete
        .OptionButtons.Delete
      End With
      For Each myCell In myRange
        'With myCell.Resize(1, maxBtns)
        With myCell '.Resize(1, maxBtns)
          Set grpBox = wks.GroupBoxes.Add(Top:=.Top, Left:=.Left, _
          Height:=.Height, Width:=.Width)
          With grpBox
            .Caption = ""
            .Visible = True 'False
          End With
        End With
        For iCtr = 0 To maxBtns - 1 'create buttons
          'With myCell.Offset(0, iCtr)
          With myCell '.Offset(0, iCtr)
                Select Case iCtr
                    Case 0
                        Set optBtn = wks.OptionButtons.Add(Top:=.Top, Left:=94, _
                    Case 1
                        Set optBtn = wks.OptionButtons.Add(Top:=.Top, Left:=140, _
                    Case 2
                        Set optBtn = wks.OptionButtons.Add(Top:=.Top, Left:=190, _
                End Select
                Select Case iCtr
                    Case 0
                        optBtn.Caption = "Sales"
                    Case 1
                        optBtn.Caption = "Service"
                    Case 2
                        optBtn.Caption = "Service Engineer"
                End Select
            If iCtr = 0 Then
              With myCell.Offset(0, -2)
                optBtn.LinkedCell = .Address(external:=True)
              End With
          End With
        Next iCtr
      Next myCell
    Running this code will create the option groups so you can see what I mean.
    Can someone give me any ideas.
    Thanks,
    Scott
    • #994012
      If you want the option buttons in one row to act as a group, you have to place a group box around them. All option buttons on a worksheet that are not placed in a group box, belong to the same group, and they share the same linked cell.
      • #994013
        Hans,
        In the code the the group box is created then the option buttons are placed in the box in each row.
        Or thats what is seems to do. I can click on the box in each row and it has a different group box number.
        But it still doesn’t act right.
        • #994020
          Sorry, I didn’t look closely enough.
          But the option buttons don’t fit entirely within the group boxes you create, that’s what causes it to fail. See attached demo, where the option buttons have been made smaller.
          • #994023
            Thanks, I modified the Left, Height, Width parameters and that did it.
    Reply To: Code help for Option Group (Excel 2000)
