As @Kirsty noted over in the Code Red forum yesterday, Cloudflare has reported a security problem with their servers which led to leaked information f
[See the full post at: Cloudflare parser leak: No problem here]
Home » Forums » Newsletter and Homepage topics » Cloudflare parser leak: No problem here
- This topic has 15 replies, 8 voices, and was last updated 8 years, 2 months ago by
anonymous.
Tags: Cloudflare
AuthorTopicViewing 4 reply threadsAuthorReplies-
NetDef
AskWoody_MVP -
GuestFebruary 26, 2017 at 4:35 am #97378NowSecure (https://www.nowsecure.com/) is also using CloudFlare. I see the big red notification box on their home page…
Woody, can you post a more specific link? I can’t find the list of affected sites on NowSecure.
ManagerFebruary 26, 2017 at 6:19 am #97385I thought it would be easy to find a definitive list of leaky sites, but nuthin’s easy on the web…
This site seems to be the most thorough: http://cloudflarelistcheck.abal.moe/
JohnW
AskWoody LoungerFebruary 27, 2017 at 11:51 am #97568Woody! Thanks for that checker!
Here’s a list of sites that use Cloudflare, but doesn’t necessarily mean they leaked. But sometimes better to be safe … it’s a long list, butyou can use your browser’s “Find” tool to search the list for site domains that you may use.
Windows 10 Pro 22H2
GuestMarch 2, 2017 at 6:10 am #98202This is not the full list. Far away from that. Hundreds of thousands of sites use CloudFlare. The Alexa top 10000 is just a fraction of that.
“Cloudflare has always terminated SSL connections through an isolated instance of NGINX that was not affected by this bug.” so if you always used https://yourcloudflarehostedsite.com, you should not worry.
However if you only typed “yourcloudflarehostedsite.com” in the address bar, browsers think you mean http://yourcloudflarehostedsite.com, and the redirection to https is made by CloudFlare. In this case, you might be affected.
Check out https://rosettacode.org/wiki/Rosetta_Code, this is how every site using CloudFlare should look like now: they should all have a big red notification bar.
JohnW
AskWoody MVP -
Guest -
ManagerFebruary 26, 2017 at 7:06 am #97392Martin Brinkmann has a discussion of two browser extensions — one for Firefox, the other for Chrome – called CloudBleed. CloudBleed scans your browsing history and tell you if you’ve ventured onto a leaky site.
Give it a try. See this ghacks article.
Kirsty
ManagerFebruary 26, 2017 at 10:44 am #97411The Firefox extension took seconds to install and check. I got 12 results, but there wasn’t anything with an account, which is worth knowing anyway.
Manager
JohnW
Kirsty
ManagerFebruary 27, 2017 at 11:50 am #97565The impact has been wide, including (reportedly) 200 iOS apps, Fitbits etc.
Reference source: https://wptavern.com/cloudflare-memory-leak-exposes-private-data
JohnW
AskWoody LoungerFebruary 27, 2017 at 12:14 pm #97573If you have deleted your browser history, the plugin can also check your bookmarks instead.
But if like me you use multiple browsers including Edge, and delete some history, I found another way.
I also use CCleaner to preserve my “good” cookies for sites with accounts. The CCleaner cookie “whitelist” makes a good list to check with with the leak checker you listed here: http://cloudflarelistcheck.abal.moe/
Windows 10 Pro 22H2
WildBill
AskWoody PlusFebruary 26, 2017 at 3:37 pm #97426I use NoScript & AdBlockPlus; usually to reach a site (like AskWoody), I temporarily allow the site I go to under NoScript. Have some hits, but I only have accounts on 2 sites. For Medium, I had to change my Twitter password, since I sign in with it.
Wild Bill Rides Again...
Viewing 4 reply threads - This topic has 15 replies, 8 voices, and was last updated 8 years, 2 months ago by
Xfinity home internet
MrJimPhelps
2 hours, 32 minutes ago -
4 hours, 31 minutes ago -
Debian 12.11 released
12 hours, 58 minutes ago -
16 hours, 39 minutes ago -
3 hours, 2 minutes ago -
Deo
13 hours, 7 minutes ago -
1 day, 9 hours ago -
healeyinpa
23 hours, 59 minutes ago -
Rick Corbett
LHiggins
12 hours, 3 minutes ago -
NO POWER IN KEYBOARD OR MOUSE
HE48AEEXX77WEN4Edbtm
4 hours, 55 minutes ago -
1 day, 21 hours ago -
Mike Cross
2 days, 11 hours ago -
19 hours, 38 minutes ago -
8 hours, 16 minutes ago -
2 days, 14 hours ago -
2 days, 2 hours ago -
2 days, 22 hours ago -
0Patch, where to begin
cassel23
2 days, 16 hours ago -
3 days, 12 hours ago -
2 days, 23 hours ago -
3 days, 20 hours ago -
3 days, 11 hours ago -
13 hours, 52 minutes ago -
Peobody
5 hours, 46 minutes ago -
EspressoWillie
3 days, 9 hours ago
