This morning for some reason ctl-c and ctl-v stopped working. I also tried cut / copy and paste from the edit menu and they did not work either. Everything seemed to be working fine yesterday.
I run XP3 with all fixes applied and word 2003 with fixes applied. I am using a Microsoft cordless keyboard and mouse. I have not made any system changes since Microsoft’s last fix update.
Initially I was trying to copy and paste from an email into fire fox’s task bar. After the problem started I experimented with a word document and copy / paste also would not work in Word.
looking at clipboard in help I noticed an error message popping up at the lower right corner of the screen that said “Clipboard – Item not collected” I have experimented with the various options shown in help and nothing has seemed to work.
I feel sure that I have made an inadvertent change which has done something to the clipboard.
Any help would be appreciated.
Tom
