• Cell Formula problem in VBA (2003)
    Hi All,
    I need to grab the formulas of some cells as strings to work with them. Generally works fine, just sFormula = oCell.formula. However, it bombs on formulas very near the formula character limit (of which, unfortunately, our users have a good amount).
    I’ve played with the formulas in question. The number of chars I need to remove in order to work with the formula in VBA is a bit variable, depending on the formula, usually I have to bring the length down to between 1007 and 1010 chars.
    I can work around this by switching to display formulas mode and grabbing the text of the cell, it seems, but I was wondering why/when this happens and if there’s any other way to work with these formulas.
    Thanks a lot.
    • #1081997
      I’d shorten formulas by using extra cells to hold intermediary results. A 1000-character formula is very difficult to understand and to maintain, IMHO.
      (And no, I don’t know a workaround)
      • #1082000
        Thanks Hans. Unfortunately they are user’s files, and stubborn users to boot, so they probably won’t break up their formulas. I’ll just use that workaround.
        Best,
    Reply To: Cell Formula problem in VBA (2003)
