• capture number of rows to be updated (Using Acc2000, with DAO)
    Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » capture number of rows to be updated (Using Acc2000, with DAO)
    Pls help.
    how can I capture how many rows I am updating within my UPDATE code.
    “You are about to update 0 rows” then
    do this
    else
    do that
    (Nice to work with warnings off also!)
    Many thanks,
    J
    Viewing 5 reply threads
    • #880459
      Use a dcount function with the same where clause as in the update query.
    • #880460
    • #880465
      I think you’d have to open a recordset based on the equivalent SELECT or SELECT DISTINCT code, then get the RecordCount of the recordset. The count will not be accurate unless you move to the end of the recordset first, but it will tell you if there are records to be updated or not.
    • #880466
    • #880471
      Use a DAO database object
      dim db as DAO.Database
      set db = currentdb
      Then use the EXECUTE method of the database object to do the update
      db.execute(“UPDATE … “)
      Then call the RECORDSAFFECTED property of the database object
      msgbox(“Updated ” & db.recordsaffected & ” records.”)
      This should work.
      You could encapsulate the operation in a transaction maybe to rollback if need be?
    • #880472
      set db = currentdb
      This should work.
    Reply To: capture number of rows to be updated (Using Acc2000, with DAO)
