• Canadian Tech: How to rebuild a Win7 system with minimal snooping
    Home » Forums » Newsletter and Homepage topics » Canadian Tech: How to rebuild a Win7 system with minimal snooping
    For those of you who need (or want) to rebuild a Win7 system, but don’t want to get stuck with all of the “telemetry,” Canadian Tech has a detailed ch
    [See the full post at: Canadian Tech: How to rebuild a Win7 system with minimal snooping]
    13 users thanked author for this post.
    Viewing 30 reply threads
    • #2006728
      I have a couple of old W7 systems just gathering dust so this could be helpful if I decided to bring them back to life for any reason.
      Thanks Woody & CT 🙂
    • #2006732
      If you want to do that, do it soon. No one know if you will be able to after Jan 14, 2020
      CT
    • #2006741
      I have a Macrium Reflect image of a so-called CT final-state win7pro installation, which I can use with Redeploy to rebuild any of my win7pro boxen. All offline, with tested rescue media as well. The OEM machines have all re-activated on their own; I also keep a list of phone activation numbers.
      • #2006742
        1. In my experience, all Dell systems automatically activate on installation. They do not require you to enter an activation code. The only provision is that the install must be of the same edition (home, pro, etc) and bitness (32 or 64) as the original product key.
        2. When you install an image of a completed system, activation has already taken place and will not be called for for any brand system. That goes for Office as well. I suspect MS activation could well cease after 1-14-20
        CT
        • #2006766
          Quote:
          “I emphasize the need for PLUS R DVD blanks. Do not use the more common MINUS R DVD blanks.”
          Why is that?
          • #2006826
            Ah, the old question about which DVD R/RW format is the “best” one to use.
            Here are two articles that may help to explain the differences (and history) between the DVD-R/RW and DVD+R/RW formats (incidentally, that’s a dash, not a minus sign, in “DVD-R/RW”):
            http://www.digitalfaq.com/guides/media/dvd-formats.htm and,
            https://www.diffen.com/difference/DVD%2BR_vs_DVD-R (note links at the bottom).
            Cheers,
            AJN
            • #2006833
              Thanks AJN. clarification appreciated.
              CT
            • #2007078
              And just to be clear, never use the /RW type for backup, as these can be overwritten and you’d possibly never know it until you try to do a restore or set up a new installation.
              -- rc primak
              • This reply was modified 5 years, 5 months ago by rc primak.
            • #2007086
              One good day Win 7 laptop stop burning DVDs: it would get right to the end of the burn, then change its mind and terminate with an error message saying that it had failed to complete the recording (which I thought was a little unnecessary). I decided the built-in DVD drive was coming to a rather earlier end of its existence, muttered something no fit for repeating here about OEMs fondness for building their machines using showy, but cheap, flimsy stuff, and started looking online for a replacement. Then I mentioned my problem here and someone (maybe you, AJNorth?) told me to check if the DVD disks I was using were + or – and to use only +. So I checked and, sure enough, found that the pack of DVDs, recently bought at the local Staples, was all – . So I went back and got a pack of + from there. Tried one of the new blank + DVDs to see if I could burn something on it and… problem solved! The optical drive was as OK as could be expected given its several years of service. The problem was caused by using DVD disks with the wrong sign!
        • #2007076
          I wonder if this event would munge CT’s whole scheme? I would hate for folks to go to all this trouble, only to find that activation is revoked and cannot be re-established.
          -- rc primak
          • #2007238
            rc, that is one of the beautiful features of this method. When you restore the image of an activated system, it is already activated.
            CT
    • #2006768
      I run multiple 32bit Win7/Ent/SP1, Office 2016 locally installed, and an upper-tier AV. All systems and software are fully patched, all set to automatically update, and I check for updates religiously. Like Canadian Tech, I haven’t had any problems with any of my systems. I don’t care about telemetry, whether MS or NSA. I have spare parts to keep all my systems going, and I will run Win7 until I die or the world ends, whichever comes first.
    • #2006824
      Anonymous, DVD MINUS R is a completely different kind of disk. It is pretty much designed for Video recordings, not data. DVD PLUS R is designed for much greater precision.
      If you use -r’s you will encounter many errors. You will not with +r’s.
      The System Image creation in Win7 writes the DVD, then reads it back to verify. -r’s will frequently fail that verification step.
      You are building something you really want to work when and if you need it. Do not take chances with technology that is not as reliable.
      When you shop you will find the vast majority that are offered are -r. Here is an example
      https://www.amazon.ca/Verbatim-4-7-upto-Recordable-Disc/dp/B0003QIXBY/ref=sr_1_4?crid=6G9T24ZI1SQL&keywords=dvd+%2Br&qid=1574018303&sprefix=dvd+%2Br%2Caps%2C156&sr=8-4
      CT
      • This reply was modified 5 years, 5 months ago by Canadian Tech.
      • #2007080
        Out of curiosity, why not use multiple copies on mechanical hard drives? Is the point of using DVD+R to prevent any possibility of overwriting of the Final Version?
        -- rc primak
        • #2007239
          I know of no reason why you could not make the image on an external hard drive. It is just that the image can be quite large and that takes a lot of space out of use for what could be a long time. This is an insurance kind of thing that you hope you will never need.
          CT
      • #2007560
        Seems like DVDs have gotten more expensive!
        BTW those are +s not -s 😉
    • #2006840
      Is it really a good idea not to use Spectre or Meltdown patches? Can they not be isolated from the other stuff? It just seems prudent to make sure those are patched, at least in case something happens with them in the future.
      Personally, I stick with the main updates and just disable telemetry after the update. I’ve never had any problems with that, either. Woody’s guide is fine.
      • #2007082
        Spectre and Meltdown have no active in the wild exploits, last time Woody revisited the topic here.
        As for “removing all the telemetry”,  we don’t even know what or where all the telemetry is, so how do you remove what you can’t even find?
        -- rc primak
        • #2007123
          Then there is the matter of the BIOS update required for complete protection.  Several of the machines that I tend to were never issued that update by their OEMs (mostly HPs, plus a few Dells), even though Intel indicated that they were available for their respective processors (and, of course, the performance hit — which can be significant).
        • #2007614
          WPD is a good program to disable all telemetry for Windows 7-10, and includes an IP blacklist. O&O Shutup only works for Windows 10.
          https://www.ghacks.net/2015/08/14/comparison-of-windows-10-privacy-tools/
          I just find it satisfying to go will all the updates, and then select, “NOPE!” a “Come and take it, you just try!” approach.
    • #2006863
      Thanks, Canadian Tech, for taken the time and trouble to explain in careful detail one way to keep running Windows 7 safely after EOL in January. I am sure that many here can benefit from it.
      For my part, running, not hundreds of computers as a professional computer OS administrator or repairer, but only my one good old laptop for my own personal business, I do have, based on my own and very personal experience, since the days of Win 98, a somewhat different take on what is coming and how to be ready for it. At least for someone in my situation, without the responsibility for any other machines other than my own.
      In particular, I have been updating in my 8.5 year-old laptop, since I first got it in 2011, both Windows 7 and Office 2010 all the way through this October and plan to continue doing so until January. Being “Group B” since before there was a Group B, or even a Woody’s, in either its present or its past “Windows Secrets” incarnation, I have, even so, never, ever had a problem caused by a bad patch. My problems have been caused by bugs in applications installed after Windows or  by “services” and software, those launching at start-up in particular, planted in my HD when installing some gadgets and said applications.
      How Come? Well: all that has taken me to achieve this healthy patching record is to look around for information on possible problems with some updates, figure out which are nonsense and which needs to be taken under advisement, then act accordingly. To this end, places such as Woody’s have been, over the years, of invaluable help. And, of course, having a measure of good luck, as is always needed for anything in life that to turn out OK in the end. Further, I am not too concerned with “telemetry” planted in these updates by MS. It is definitely a worry, but way, way, way down in my list of what-to-worry-about priorities.
      But, other than the above disagreement with following some  parts of Canadian Tech’s recipe, I heartily agree with doing so with others, such as the idea of setting Windows Update to never to update, unless one learns that there is something available for Win 7 after its end of life that might be worth installing, strictly for security reasons. Other than that, it is Group W for ever — or unless until some extended support service is offered and proven in practice to be a good thing to use.
      I also plan to keep the AV up to date for as long as it is supported, as well as other applications needed to protect the PC from malignant intrusions. And use preferentially, as the OS for Internet access, Linux Mint, that now I have installed on the PC in dual-boot with Win 7.
    • #2006874
      And then buy extended security updates.  If you spend this long rebuilding, don’t use it for surfing.
    • #2006881
      In my view it’s time to drop KB3020369 from any given tutorial. The patches you can’t do without now are KB4474419 and KB4490628. It takes both for SHA-2 signing support, with KB4490628 taking the place of KB3020369. Also see:
      https://www.bleepingcomputer.com/forums/t/707375/can-i-reset-windows-7-and-receive-updates/page-2#entry4904195
      Regards, VZ
      • #2006897
        In this case, @Canadian-Tech recommends not patching any update after May 2017. KB3020369 qualifies for this timeframe. If you are not currently installing any updates, the SHA-2 coding support and the later Servicing Stack KB4474419 and KB4490628 are irrelevant.
        • #2007452
          but KB3020369 is an obsolete update and KB3177467 should be used instead. avoid using KB3020369 since windows update does not offer that one anymore
          KB3177467 was originally released in late September 2016 but got a V2 release on October 2018 as a “security update”. download & install KB3177467 from MS Update Catalog:
          https://www.catalog.update.microsoft.com/Search.aspx?q=3177467
          • This reply was modified 5 years, 5 months ago by EP.
          • #2007563
            EP, You are correct, but that update was issued October 2018. I do not apply any updates that were issued after May 2017.
            The process I describe here works. I know it works. I have done it literally hundreds of times. Many others have followed it as well. Microsoft could screw it up between now and mid January, but up till now it does work.
            After mid January, all bets are off. I would not be surprised if Microsoft pulls those updates that are listed here.
            If you cannot get to this until after mid January, download and store those updates before then. I have done so.
            The problem will be, if Microsoft pulls Win7 updating, you will not be able to bring your newly installed system up to the point where my procedure starts.
            CT
    • #2006995
      Thank you  Canadian Tech  and Woody,  I have bookmarked the full post webpage that Woody references:
      I use the Firefox extension – Print Friendly & PDF to make a PDF version for my reference and will attach here for others that like PDF.  Good work Canadian Tech.
      • #2007375
        lars, would you please make a new pdf of that? two of the links were defective and have since been fixed by PKcano.
        CT
        • #2007561
          Hello CT and Lars,
          Attached is a freshly-made PDF (created a few hours ago).
          Cheers,
          AJN
    • #2006997
      We are aware of some issues with the links as they are currently formatted.
      We are working on fixing this – please bear with us!
    • #2007090
      This seems like a lot of trouble to go through to avoid having a modern operating system.
      The other thing I can’t get out of my mind is how many businesses and individuals stuck with Windows XP — until the day a massive new attack for which XP’s security had no defense came along. Microsoft was obliged to issue an emergency patch, but that did not make XP systems perfectly safe again.
      I fear that this idea of “freezing” the “perfect” Windows installation and never updating it may lead Windows 7 die-hards down the same Primrose Path.
      For all this effort, I could teach a complete newby how to get by in Linux Mint. Even if you think you have “indispensable programs” which are “Windows only”. With very few exceptions for highly technical business programs, there are decent Linux equivalents. You just have to know where and how to look for them. Worst case, you run WINE or a Virtual Machine inside Mint or Ubuntu. The host OS (Linux) is providing all the security in these scenarios, so not being up to date in the VM is nearly irrelevant, as long as your drivers and activation are working.
      If Windows 7 activation ever ceases, that could be a whole different kettle of fish. But Windows XP can’t be activated now, and there are some who still run Windows XP in VMs. I don’t know how they do it. Or why, unless some specific software was never updated by the vendor. And has no Linux equivalent. That would be a rare case indeed.
      -- rc primak
      • #2007094
        There are plenty of production W7 systems that can’t (yet) be replaced so having detailed re-build instructions is a great help.
        Home use is a very different arrangement and up to the individual.
      • #2007104
        rc primak: I do agree with you, and would add that, if there is enough space on disk, one could install Linux in dual-boot with Win 7 and use the Linux side of the PC for surfing the Web and doing email and other Internet-related activities. Files downloaded in this way can then be passed to the Windows side, after scanning them for viruses. And any rare security update coming from MS can still be installed in Windows. A perfectly safe arrangement? No. But what is ever perfect in this sublunary world? But this way forward is right for me, maybe for you, but not for everybody.
        I do understand that Canadian Tech is addressing users with similar concerns motivated by being in a similar situation as CT: they all have to take care of many computers their owners want to keep on using with Win 7, the operating system they are familiar with; and, or like; and, or need because of some very useful software they have set up just right and would be a tremendous hassle and waste of time to look for a suitable replacement and then set it up to be, once more, just right for its intended purpose. And, or — for whatever reason, including the good one mentioned by Paul T just before this posting– they are required by their bosses to keep using Win 7. And, or are just plain ornery people that don’t like to change anything, ever, so there is no point trying to convince them to change their minds.
        • #2007137
          If your boss requires that you stick with Windows 7, your boss should be looking after your updates and security. And your boss should be fixing any problem which result from sticking with an unsupported OS version. That should be a contract requirement. Betcha very few bosses do that.
          -- rc primak
      • #2007345
        RC, lets not get out of perspective. This is a solution for Aunt Martha. The aunt who uses her Windows 7 system for email, a bit of browsing and possibly Facebook. She uses it for maybe half an hour ever few days. For her, a very simple system fits her needs just fine.
        This is not a solution for every Techie or user who is technically competent.
        Keep in mind that “Aunt Martha” is a description for the vast majority of computer “users.” The people like you and I who lurk in this corner are techies who have different much more sophisticated needs.
        CT
    • #2007672
      Anything is possible, but I’d be very surprised if the ability to activate Windows 7 licenses were to stop anytime soon after January 2020. It may be reassuring to know that Vista could still be activated as of this past summer (I did it).
      • #2007673
        Cybertooth, thanks. I think you are probably right. In fact, I’d put 10 to 1 odds on it. I am just not willing to take the risk. Microsoft never considered Vista a risk. It considers Windows 7 a huge risk because the market still has something like 35% Win7 after 4 years of not being able to buy a Win7 system. So, I am not certain that past behaviour is a good indicator. Particularly in this case.
        CT
        • #2007678
          I don’t think they can afford to stop activation, not at least for a minimum of three more years until 2023. There are going to be a lot of people buy into the extended support that may, at some point, have to reinstall and reactivate.
        • #2007682
          Windows 7 market share is now below 28% – and I’ve seen no evidence that Microsoft considers Windows 7 to be any sort of “risk.”
    • #2007679
      That would be sensible. I am not sure the decisions (especially the executive ones) being made the past few years at MS have all been sensible.
      CT
    • #2007877
      Canadian Tech: Thanks for this. A couple of points:
      1. You state that you do not update after the May 2017 security only (SO) and IE updates because the June 2017 SO update had a bug only fixed in a later rollup update. I don’t remember reading about this at the time, but after a little searching I found https://appuals.com/fix-something-went-wrong-and-your-search-couldnt-be-completed/  which describes a problem with searching in Outlook caused by the June 2017 SO update KB4022722 and which can be addressed by the “hot-fix” “standalone package” at a link which connects to the June “Preview” Quality Rollup KB4022168. Is this what you are referring to and the specific reason you abandoned further updating? (I see your point in principle, that bugs in SO updates should be fixed in SO updates, but as I don’t use Outlook I would probably not encounter this specific problem in practice.)
      2. Thanks for the advice about DVD+R disks. A few years ago I was using the Windows “create a system partition image” mechanism to backup to DVDs, but when I needed to restore from one of these backups it failed. Out of about 10 such backups about half failed. At the time I assumed that this was a problem with the Windows create/backup and restore software, but based on your comments it may have been because the images were burnt to DVD-R disks 🙂 (I no longer have the disks so cannot check.)
      3. Following my point 2. above, it might be a good idea to add a few words to your instructions to remind people to create their restoration media e.g. W7 rescue disk if using the Windows create/backup mechanism or a 3rd party restore thing if using a 3rd party tool such as Macrium Reflect AND if this is on a DVD it also should be DVD+R (not -R).
      Thanks. Garbo.
      PS: I have created what are effectively “factory recovery” images similar to yours since I replaced Windows XP with W7, when the actual “factory recovery” mechanism from the PC manufacturer restoring XP became obsolete. For a long time I used bootable Partition Manager disks (DVD-R – my bad!) to copy the system partition mid-installation to a new partition in the slowest, inner part of the hard disk drive and later copy it back to the faster, outer system partition to restore.
      More recently I have also created Macrium Reflect images of these mid-installation system partitions, so I have 2 mechanisms and hence some redundancy.
      • #2007985
        It would help to provide some background:
        I provide support for about 120 Win7 client systems. These are people much like the Aunt Martha described earlier. They do NOT include enterprise or business situations, gamers or intense technical people. My objective is to bring stability, ease of use and payoff from an investment (the PC). In reality, when you leave out enterprise installations, my clients are actually quite typical of the vast majority of computer users.
        As an underlying strategy, I avoid as much technology as possible. i want my clients to be able to support themselves as much as possible, should I not be available.
        Hence, although I have no doubt that software like Macrium is likely superior, it is just one more step to the technical side as opposed to using what is already built-in to Windows 7 itself. I have used the “System Image” function in Win7 hundreds of times with near perfect success. I simply produce a pack of 2 to 6 DVD’s which I tell them is insurance. Keep them safe and know where they are.
        My conclusions in mid-2017 were that Microsoft had made such a muck up of Windows Update that it was well beyond Aunt Martha’s capability to manage the Update process, and that perhaps we should take the risk of not updating, since it was pretty clear that to continue to pursue the Windows Update paranoia would result in systems that could no longer be used.
        I visit the Ask Woody site daily. When I read the many stories of the mess they call Windows Update, I oddly smile and have a feeling of “that is someone else’s problem”. I have divorced myself and my clients from this mess and they are not only not worse for the decision, but in fact, far better off. There are some serious respectable experts who roam the halls of Woody and offer streams of advice on how to minimize the damage that WU does.
        The results in the ensuing 30 months have been quite stunning. My phone rarely rings any more. My work-load to support these people has fallen off by at least 75% and more like 90%.
        There has not been a single instance of any kind of problem.
        In fact, these systems are as stable as residential heating systems. Rarely needing concern and only maybe annual checkups for potential hardware failures. These systems rarely change. The only changes (updates) that take place are from Chrome and BitDefender, and those are under the covers and not obvious to my clients.
        This story would not be complete without talking about the mess that they call Windows 10. For many reasons I will not go into here, I have not purchased a Win10 system, nor do I ever intend to do so. In years past, that would have been an impossible scenario. However, in today’s world, the vast majority of most people’s computer needs are served well from a tiny device they carry in a shirt or hip pocket. The one that is operated by Google’s Android system. The computer in every home idea has transformed into a computer in every shirt pocket
        My clientelle has fallen off from 4 years ago when it was 150 systems. Of those 30 systems, maybe 5 or 6 bought Windows 10 systems. A few bought Apple systems. The others simply no longer have a computer. Other than those 5 or 6 systems, my clients who used to buy new ones at about 30 per year have not bought a computer is the last 3 years. The computer store which regarded me as a regular customer rarely sees me any longer. I no longer have a sales rep contact at Dell.
        CT
    • #2008381
      Great guide, thanks!
      Fractal Design Pop Air * Thermaltake Toughpower GF3 750W * ASUS TUF GAMING B560M-PLUS * Intel Core i9-11900K * 4 x 8 GB G.Skill Aegis DDR4 3600 MHz CL16 * ASRock RX 6800 XT Phantom Gaming 16GB OC * XPG GAMMIX S70 BLADE 1TB * SanDisk Ultra 3D 1TB * Samsung EVO 840 250GB * DVD RW Lite-ON iHAS 124 * Windows 10 Pro 22H2 64-bit Insider * Windows 11 Pro Beta Insider
    • #2366608
      Hi, thanks for creating this blog.
      Have you abandoned support for Window 7? I noticed most of the links don’t go anywhere. I have to manually search for the KB bulletin file. God only knows how long we have before Microsoft deletes those too.
      Should you do some housekeeping, perhaps you can number each download so we know the order we should be downloading eg.
      1. KB3138612
      2. KB3138612
      As another suggestion, perhaps you can compile all the downloads into one large compressed iso in the form of a slipstream DVD?
    • #2366861
      Has something changed? I am now getting driver error messages that they must be signed. Even my older external hard drive has this error which worked before now even when I try to access it from the old image. I have tried some workarounds to disable signing, and they don’t really work. I had no issue over a year ago.
      Additionally, my Windows Defender can’t be turned on and I don’t even have the option to check for Windows Updates at all. There are a few places online that have SP 1 but I don’t know if they are the original as they vary in size.
      More concerning is despite the installation method or Windows version (even from a working drive image) I am now getting SFC corruption errors which can’t be repaired.
    • #2366897
      I have not allowed Windows Update to run on any of my clients’ Win7 systems for 4 years now. They number nearly 100. There has not been a single instance of any kind of a problem. Simply totally stable systems that just work day after day.
      From that, although I certainly could not prove it, I would conclude the problems you describe are the result of allowing WU to continue to operate.
      My recommendation then and now is to re-install just as described originally. The only difference is the need to deal with the SHA2 problem:
      SHA-2 code sign support for Windows Update
      You must install the updates KB4474419 and KB4490628 in order to rectify error 80244019, if you are using Windows 7 so as to enable SHA-2 code sign support, and to install updates signed by using only the SHA-2 algorithm by Microsoft, respectively.
      Please go to Microsoft Update Catalog through the links given below and download the update which matches your computer architecture.
      https://www.catalog.update.microsoft.com/search.aspx?q=kb4474419
      https://www.catalog.update.microsoft.com/search.aspx?q=kb4490628
      http://download.windowsupdate.com/d/msdownload/update/software/secu/2019/09/windows6.0-kb4474419-v4-x64_09cb148f6ef10779d7352b7269d66a7f23019207.msu 64 bit
      http://download.windowsupdate.com/d/msdownload/update/software/secu/2019/09/windows6.0-kb4474419-v4-x86_fd568cb47870cd8ed5ba10e1dd3c49061894030e.msu 32 bit
      http://download.windowsupdate.com/c/msdownload/update/software/secu/2019/03/windows6.1-kb4490628-x64_d3de52d6987f7c8bdc2c015dca69eac96047c76e.msu 64 bit
      http://download.windowsupdate.com/c/msdownload/update/software/secu/2019/03/windows6.1-kb4490628-x86_3cdb3df55b9cd7ef7fcb24fc4e237ea287ad0992.msu 32 bit
      CT
    • #2367020
      Hi. Thanks for replying. I reverted to a full Windows 7 image that had ALL the updates possible to be installed. I verified I in fact do have KB4474419 and KB4490628. I am still plagued by driver signing errors.Are they caused by SHA-2 issues?
      I don’t think we can blame Windows Update here. I was completely disconnected from the internet and disabled automatic updates after running a bare-bones installation (as soon as Windows booted the first time). All these issues including WD not functioning occurred right after installation….with zero updating online and no Windows updates installed.
      Furthermore, I just installed my Brother All in One Laser Printer from a CD and then proceeded to download from Brother’s website. I still have the driver errors. I am now running Windows 7 in “test” mode and I have the annoying text on the bottom right-hand screen saying that and my version number. The “test” mode is from running this from the command line: bcdedit.exe -set TESTSIGNING ON.
      Additionally, when I created my new Windows 7 image back in late December 2020 and this January (2021) I had none of these errors. The reason I know this is because I have been trying different images of my HDD that I created recently. All my issues are  very new and sudden.
    • #2367023
      As I already told you, I have strong suspicion you are the victim of boad Windows Update(s). There are a lot of them. It could also be bad software from Brother. Have you used driver update sites on teh Internet? They are just about universally bad news.
      CT
      • #2367029
        I’m running a Win7 ESU patched here and not seeing issues?
      • #2367030
        I don’t think you’re understanding me, or I’m not being clear.
        My issues with digital drivers and more happen immediately after I install Windows and I am NOT connected to the Internet when I did a fresh install and when I boot up Windows.
        I am using my factory installation CD and the CDs that came with my motherboard and video card (original drivers) meaning NOTHING is downloaded. Any applications that I have are old applications and that are “side-loaded”. Let’s not point fingers here unless you replicated my actions today.
        To further clarify, my other Windows 7 PCs do not have this issue. They only happen AFTER doing a brand new install with SP1. It makes no difference whether the installation is from an OLD HDD IMAGE or from a FRESH install (without being connected to the internet). Remember, some of us don’t have Wi-Fi on our PCs so unplugging the cable is what I do.
        If I had kept everything “as is” and never wiped my HDD, I would have no issue. That’s what’s so unusual.
        Why not follow your guide (today) and report back your results?
        • #2367034
          If all you are doing is SP1 there are some cert fix patches that have to be loaded back in that may be impacting you.
          http://wu.krelay.de/en/
          See that page, see if any of those servicing stack patches fix you up?
        • #2367039
          I am not certain you are addressing me.
          I suspect that is coming from software on the MB installation CD. I have never seen this from Windows.
          CT
          • #2367477
            Canadian Tech:
            With all due respect. You’re not [listening] me. Please pause and reflect on what I have written and refrain from coming to conclusions based on your experiences. What I have encountered is brand new. You remain absolute and opinionated despite refusing to install Windows 7 from scratch to prove the outcome is now the [new] normal.
            I am going to explain (again) one last time what I am going through. If for no other purpose, for reference purposes should others attempt to reinstall Windows 7.
            When I do a basic installation of Windows (from my original 2010 DVD) that did NOT come with SP1, everything is fine. Defender works and I assume Windows Update does. I disconnect from the internet so I don’t know. But I can’t do anything with that version of Windows without SP1.
            After I install SP1 that’s when the trouble begins. It doesn’t matter the source of SP1. I have tried using an archived files on my PC, CDs, other hard drives, nd new downloads from Microsoft. I even used the Microsoft Windows 7ISO file that I downloaded from their site. I used countless old HD images going back to 2013 and they all have SP1 installed.
            The results are ALL the same: defender no longer works, I have unsigned digital driver issues and the drivers are not installed because of the lack of digital signing. This affected my native video card and SATA/USB, controllers. Windows wouldn’t install them.
            I must emphasize, I installed Windows 7 SP1 from different sources and the result is the same. My last known good image was from Dec, 2020. Even when installing older images, the outcome is identical. Any new installations like printer or USB drivers fail, even with known good installations. There are no issues with Windows 8.1 whatsoever. I repeat, there are NO ISSUES WITH WINDOWS 8.1 which is still supported.
            What just started occurring now since I copied my files back to my Windows7 is Windows is telling me there’s an activation concern with my OEM version of Windows, It is actually a legitimate CD.
            Every few hours or even minutes a message popups (see attachment). Despite verifying in PowerShell and My System, my Windows is Activated. This popup and false-positive happen every few minutes. My solution is to keep on reentering the product key every time this happens.
            I am going to speculate that within Windows 7 SP1 telemetry, there is a command that crippled Windows Defender, Windows Update, and requiring digital driver signing of new installations effective sometime in 2021. Whether you choose not to believe this is up to you. The fact remains, ALL my issues disappear when I install Windows 8.1.
            • #2367497
              HMM, I have installed Win7 every which way likely on several hundred PCs. I have never encountered the behaviour you describe.
              I am sorry I cannot be of more assistance.
              CT
            • #2367509
              You installed Windows 7 on hundreds of PC since January 1, 2021?
            • #2367605
              At reinstalling Windows 7 in 2021, like today, the following occurs:
              Windows 7 RTM: Windows Update does not work. The effects of the following article apply: https://www.askwoody.com/forums/topic/windows-7s-windows-update-will-no-longer-work-out-of-the-box/
              Windows Update in Windows 7 RTM cannot be recovered.
              Windows 7 SP1: Windows Update does not work. That is despite the effects of the SHA-1 based endpoint deprecation not applying.
              Windows Update in Windows 7 SP1 can be recovered by installing an appropriate version of the Windows Update Client, like the March 2016 one, KB3138612.
            • #2367587
              The CT method in summary is: install the basic Windows 7 plus SP1, then only install selected updates after that point.
              As I understand your scenario you are trying to reach CT’s starting point in 2 stages: firstly by installing W7 from one original installation DVD which came with your PC, and then secondly by installing SP1 from a 2nd original installation DVD. Your problems occur after installing/updating from this 2nd SP1 DVD. (At least that is what I think you are stating?)
              Nowadays W7 installation media usually has both the original W7 and the SP1 stuff together in the same media to be put on a single DVD/USB stick and both are installed at the same time. (Presumably if the installer finds a more up to date version of something in the SP1 files, it installs that rather than the same earlier, now out of date thing in the original W7 installation. Or maybe this combined media only contains the latest version? Dunno.)
              When I re-installed W7 on a 2nd hand, refurbished (presumably ex-business) PC a couple of years ago, I had no installation disk(s) for it, so I downloaded W7 which also included SP1 in the same media (for the same type i.e. Pro, 64 bit) from the Heidoc site (using their tool) and successfully installed W7 plus SP1 all in one go, not in 2 stages which you are trying to do.
              Rather than continue to bang your head against a brick wall using your original installation disks, you might have more success with this more recent, all in one, single “W7 plus SP1” installation media and be able to do it all in one go rather than 2 stages.
              Just a thought.
            • #2367635
              anonymous (who ever that is).. Incorrect. I always use a Win7 installation DVD with SP1 included. Far easier to do. Attempting the install on an earlier disk creates all kinds of problems. If you read the original text, it says that clearly.
              CT
    • #2367113
      A Windows 7 in my house has blocked updates since Windows 10 was out (7 years). This PC is in use every day for long hours and is totally stable, never a crash, bug, …
      The PC is used by a knowledgeable user.
      On the other hand, I help to maintain my brother’s Windows 7 and he has no PC knowledge I have subscribed his Windows 7 to 0Patch Pro.
      • #2367166
        Alex my clientelle are all casual non-expert users. That’s 4 years with 100+ PCs without a patch and without a single problem. The critical provisions are: BitDefender AV+, Chrome, NO Adobe stuff.
        CT
    • #2367506
      @Hmm888 – I wonder if either of the following might be related to your activation issues.
      https://www.askwoody.com/2017/report-of-kb-4038777-breaking-activation-on-dell-machines/
      https://www.askwoody.com/forums/topic/why-kb971033-should-be-uninstalled-and-hidden-on-windows-7/#post-126573
      Don’t know whether you’ve got a Dell or not, but the second link is not specific to Dell.
    • #2367510
      Canadian Tech, have you installed Windows 7 recently, as in 2021? Like I said, everything was fine until 2021. That seems to be the trigger here.
    • #2367511
      Thanks. No. It’s a custom-built PC from professionals. It was top tier back in 2011. I UNinstalled KB971033. Let’s how that goes.
    • #2367521
      @Canadian-Tech
      Is all of this still current for you?
      e.g. Installing KB3138612 and KB3020369 if need be.
      Should I not just install the latest SSU?
      What about KB3172605 which is said to greatly speed up update search times?
      The SHA-2 update KB4474419 or even the older KB3033929 (required for some drivers)
      Newer IE11 cumulatives, .NET security rollups and newer Security-Only for Windows?
    • #2367616
      The methods in the two links in #2366868 above cover the prerequisite installations necessary to make a clean install of Win7 functional and able to use Windows Update.
      You do not have to install all the way to EOL status.
      You can stop at the point Canadian Tech does.
      You can use Security-only updates if you so desire.
      But there are certain KBs that must be installed before you have access to Windows Update or install later updates manually.
      • #2367666
        So you don’t believe KB3020369, KB3033929, KB3138612 or KB3172605 are required?
        I am doing all of my updates manually and have several folders of .msu files I will be installing in batches using DISM.
        I’m just wondering why Canadian-Tech does not include some of the updates that you and many others do, like the latest cumulative IE11, .NET roll-ups, SHA-2 and SSU updates. If I stop where he does, I wouldn’t have those updates. In my case I know a driver I need requires SHA-2 support, which is why I mention KB3033929
        Yet he does include some updates no one else does, like KB3138612 and KB3020369
        I’m guessing it’s mostly a question of supercedence, and Canadian-Tech not trusting Microsoft’s patching practices post-May 2017.
        I intended on starting with his recommendations, but going as far as installing all the Group B security updates, but doing so manually up until the .net rollups, which I haven’t seen a list of downloads for yet. I would prefer to also install those manually if possible.
        • #2367672
          I have no idea where you got this idea. I said nothing specific, just a reference/links to previous methodology.
          And the above post is about choices YOU can make on how to proceede, not my recommendations.
          However, the methods used in the linked threads WORK, if you want to follow what is said about prerequisites therein.
        • #2367673
          Cormy, You are correct. I do not trust Microsoft Updates after that date. They are riddled with errors and the vast majority are of no real value.
          Not one of those 100 Win7 PCs have had a single Microsoft update since then. AND, they continue to run like well oiled machines day in day out. Not one, not one single instance of any kind of a problem.
          It is crucial that you have a top-rated AV installed. I use BitDefender AV+ in every one of them. It is so good, that when I run malware detectors it almost always comes up empty.
          KB3020369 is rarely needed, but I always try it. It will almost always tell you it is already installed. In almost all cases, KB3138612 is the only update needed.
          I suspect like a lot of things, when you follow instructions then modify them, you get a different result. I know for certain that what I posted here worked and still works and the result is Windows machines that are effectively steady-state and do not cause any problems.
          The real magic is that once you have done all the updating as I have laid out, you create a system image. That image is worth its weight in gold because at any point in time you can restore it and you have a completely running system with all its drivers, all updates needed, and to top it off, it is already activated. In most systems that takes about 1/2 hour.
          CT
          • #2369532
            You don’t mention whether you accept Recommended updates the same as Important updates, and there are a few optional updates I’ve seen PKCano recommend, such as the User and Kernel-Mode Driver Frameworks, along with the ActiveX Killbits patches.
            You also don’t mention which versions of .NET you recommend…? Following the guide, I think I would only have the default 3.5.1, while Windows update tries to give .NET 4.8 and others recommend 4.5.2 or 4.6.1, though they’ll be entering end of service in 2022 so maybe 4.6.2…?
            I think there was also a .net Framework 4 Client Profile Driver I wasn’t sure whether I should install.
            • #2369533
              Again, to be perfectly clear…. After following the specific updates listed in my process, NO OTHER MICROSOFT UPDATES ARE ACCEPTED. Not even Office, not even optional, not even Defender. Defender itself is pretty useless if you use a top end Anti Virus program. Point of clarification.. I never allow “security” software. Just the AV.
              Optional updates rarely offers anything of value. Their driver updates are not trust worthy at all.
              Kernel-Mode Driver Frameworks, along with the ActiveX Killbits patches are likely OK. I urge you to be highly selective. Very few Microsoft Updates do much for the typical user. It is simply amazing how many machines I see and hear about commonly that have NEVER had an update and the user never had a problem. Most common are the ones that don’t even have SP1, yet they continue to what most users want from them day in day out. Most of those machines end up in the scrap heap when they are replaced because they no longer work.
              Personally, I am suspicious that Windows Updating may do much more for enterprise installations and Microsoft than the average jane/joe installation.
              .Net updates, I accept what is offered. I know of no instance of a case where .net updates caused a problem. My process does not mention .net updates specifically, but is still covered, as long as they are not “rollups”.
              But let me emphasize. After the May 2017 updates the system is set for Never check and that never changes. As well we do not allow or accept any MS update after that date. As a matter of fact, ONE, just one of my clients changed the setting and allowed MS updates to be added. I told him if he wants me to work on his machine again, my first step would be re-install.
              I re-installed Windows 7 on almost all those 100 machines in 2017. From time to time, I get a used machine that I recover and load following that same procedure. So, I know it still works.
              CT
            • #2369681
              Though your process mentions .net UPDATES, it doesn’t mention new .net version installations.
              So you just stick with the default 3.5.1? The only one offered by updates is 4.8 now, but I believe it is also an optional download, and from what I’ve seen on AskWoody most would prefer older versions like 4.5.2 and 4.6.1
              “[Hide] a<span style=”font-family: Georgia;”><span style=”color: #333333;”>nything labeled Roll-up, with the exception of .net roll-ups”
              I thought we installed .net roll-ups? Or do you just mean after May 2017 you stopped installing .net roll-ups?
              </span></span>
              Is it normal that after I finish your process of updating, I’m not offered newer security patches at all? It’s quite strange to me how few updates get offered to me through this method.
            • #2369694
              Cormy, Once I install Win7 in the manner described, the machine is NEVER updated with MS updates again — of any kind. If I am now installing Win7 on a machine, I will use whatever .net updates are offered as long as they are not rollups.
              I have no idea what updates MS offers AFTER I do the install. The machines are set to NEVER…. and that really means never.
              Windows Updates once had an excellent reputation for need and effectiveness, as well as being bug free. Then in 2014 when MS fired the team that did QC on WU, things went from bad to worse. Ever since then the quality of updates has gotten worse and worse. Even Susan recommends not using updates fresh out of the hpper because of the high liklihood that they will be defective.
              On top of the QC problem, back in 2014, MS (without anouncin it) started moving WU to a “feature” update program. Most of WU is to change things in Windows that have nothing to do with security, other than fixing their own WU bugs.
              CT
    • #2435237
      Hello All,
      I have read the post regarding rebuilding Win7, which essentially says that *all* that is needed after a reinstall of Win7 SP1 is to apply one or both of KB3138612 and KB3020369,
      and afterwards only the listed security patches (until may 2017).
      But that post was created *BEFORE* Jan 2020.
      So, my question is:
      If today, in March 2022 I perform a new installation of Win 7 SP1,
      and I do *NOT* want to limit in any way the updates that became available after SP1
      (up to Jan 2020), will those updates be offered *AGAIN TODAY* when running
      Windows Update, even if , normally, there are no more updates released/offered
      since Jan 2020 ?
      The two KB updates indicated above are rather old, dated in 2016.
      Or, let me ask the same question differently:
      If today, in March 2022, I perform a NEW installation of Win7 + SP1 ,
      is it sufficient to (manually) install ONLY THE LAST monthly rollup update from Jan 2020,
      which is KB4534310 (and its prerequisite KB-s), or there is a need to install ALL the intermediary updates, since SP1 up to Jan 2020 ?
      I ask this question because, though I do have an image backup of my Win 7 machine,
      it might happen that it will have to be reinstalled due to some hardware problems,
      possibly on a different hardware.
      It would be extremely useful to have a *FINAL* updated list of ALL the steps that should be performed for a NEW installation of Win7 performed *AFTER* Jan 2020,
      so that to include ALL the updates ?
      As fard as I have seen, other posters have asked for the same.
      Thanks a lot in advance & Best Regards,
      Iudith
      • #2435259
        There are two Topics I would suggest you read. They are old and were written before Win7 EOL.
        You will not be able to use Windows Update with just the two updates you mention (KB3138612 and KB3020369). Even some of the prerequisites mentioned in the threads have been superseded. But it will give you information about how to go about updating a clean install of Win7 SP1.
        They are long, and there are multiple linked items. But the knowledge will help.
        https://www.askwoody.com/forums/topic/any-advise-on-how-to-safely-update-a-new-win-7-home-premium-install/#post-1977331
        https://www.askwoody.com/forums/topic/asking-for-a-favor-about-updating-my-win-7/#post-1907521
      • #2435263
        Judith, I am the author of that long ago posting. I still use it today. I have 88 clients who still have machines set up that way. They run flawlessly day after day after day.
        Of course, you are welcome to continue with other updates. However, I strongly recommend you make a system image after completing the processs as I outlined. You may need to go back to it. Many Win7 systems that have allowed that have significant problems that are hard to explain.
        CT
        • #2435412
          Hello Canadian Tech,
          I came around the long post yesterday, while looking “in parallel” after different sources of information.
          I think that I now have a clear image of a precise list of KB-s that should be applied at various points, and I just wanted to make sure that my understanding is correct about the following points:
          1. The list of KB-s to apply is NOT short, but it is still much, much shorter than having to apply manually ALL the KB-s that were applied along the many years.
          2. Some of the KB-s in that list are indicated as “service stack updates”, and their
          meaning is described as “to make the automatic update to work”.
          Therefore, I just wanted to make sure that the Automatic Update *can* work even if we are now PAST the EOL date.
          I see that ALL the monthly KB-s are still available for download on Microsoft’s site,
          so, at least theoretically, I don’t see any reason for the Automatic Update being unable
          to use them if needed, except if there is some “hard limit” imposed by Microsoft’s policy after the EOL …
          I would rather prefer to not tamper with decisions regrading which updates were important and which are less important …
          As we know Microsoft, it is probably correct to state that most of them were not exactly essential for the OS functioning …
          Also, honestly, when the EOL day arrived, I would have expected from Microsoft to create and offer a “single cumulative update” (similar to an SP2), containing ALL the updates required for a single step update from SP1 to SP2  … but this seems to be too much to expect from them …
          The fact is that, when the EOL day arrived, I has a very strong feeling of relief, not having “to pray” each month that the monthly update would go smoothly, without corrupting everything … One of the reasons that I prefer to continue to use Win7
          is that I don’t feel like starting again to tamper with update issues, bugs, restrictions, a.s.o. …
          Thank you so much and Best Regards,
          Iudith
          • #2435415
            I recommend you do not allow Automatic updating. You can still do updating when you wish and be selective to a point manually.
            In my case and all my clients, auto updating is disabled.
            CT
    • #2435429
      With respect, an updated [final] unified post-EOL procedure for the clean reinstallation of Win 7 would doubtless be extremely useful to (and very much appreciated by) a great many users.
      In addition, should it be necessary, a fork in the procedure to allow for successfully incorporating the Microsoft Extended Support Updates (ESU), or those from 0Patch, could also be added.
      Cheers,
      AJN
      • #2435456
        I was also going to add that 0Patch is a good alternative. I’ve been using 0Patch on my Win 7 laptop – just started my third year with them – and all seems to work just fine. Patches are unobtrusive and they keep up to date with threats. I recommend them and it is very affordable. I hope they continue supporting Win 7 after this next year!
        • #2435472
          Yes, I have been quite pleased with them, as well (I have 0Patch installed on eleven Windows 7 machines that are under my wing), and share your hope that they are able to continue crafting the patches necessary to keep Win 7 safely usable.  (There is also an ongoing discussion within the company about the possibility of offering patches for Windows 10 after it goes EOL.)
      • #2435678
        Exactly, that is what probably many, many users would highly appreciate to have, now for Win7, later on for Win10, a.s.o.
        All this mess could have been avoided if Microsoft had not denied us the possibility to restore a system image backup on a different machine …
        … not to add that, in fact, sometimes you encounter issues that no one can definitely say whether there are OS bugs or hardware problems …
        This makes us consume a lot of time researching what to do …
        From the very first days of Microsoft & Windows, a “common” solution for many problems was to restart the machine … or reinstall the OS … when, in fact, some more convenient possibilities should have been expected …
        Thank you all 🙂
        • #2435785
          I’ve moved a hard drive to a different shell of a computer and it’s worked just fine and reactivated just fine.  Windows 7 is VERY similar to 10 where it will have a few hardware “!” in the driver section and after a few reboots it’s all happy again. Third party disk imaging software is always vastly superior to native Windows backup.
          • #2435896
            What do you mean by “a different shell of a computer” ?
            I am not an installations specialist … but, logically, I have never understood why exactly you can’t just take your OS hard drive and plug it into a different machine,
            of course, supposing that the problem is not related to the hard drive itself ?
            This way Microsoft can also be sure that your OS is not “multiplied” without an additional licence.
            I perfectly agree with you that 3rd party software is superior to Windows backup.
            I once tried to do a simple restore to a standard Windows restore point,
            and it failed … so it looks indeed unreliable even for restoring the Registry only 🙁
            A few months ago I was happy to find a nice 3rd party backup software, which is simple to use and I was able to both take a windows image backup and create a restore/rescue disk that works 🙂  … after once in the past, trying the same with a more professional backup software, it did not work … maybe due to some Windows bug …
            The best thing, if somebody would take upon himself the challenge, would be to create a “service-pack”-like installation file, containing ALL the updates required for going from Win7 SP1 up to the EOL version, starting from a clean installation of Win7 + SP1, regardless of any hardware specifics.
            • #2435897
              Each computer has a suprisingly large array of devices and they are almost always different in some way — even among computers of the same model. Those devices require drivers which are loaded as part of the OS installation. So, when you move a hard drive to another computer, the chances that it has the same devices (and therefore needs the same drivers) are slim.
              Restore causes lots of people problems. The most common is that their AV software prevents it from working. The best way to avoid that is to start the PC in safe mode to do a restore. Also, the number of restore images stored by default is small — usually about 3. On my clients’ computers, I routinely extend that restore space quite a bit. That results in far more options.
              Over the years serving hundreds of clients’ computers, I have too many times found that they needed to recover from a backup and the software that made the backup (and therefore the same software that does the restore) no longer exists or the client does not have it because it was on the drive that is being replaced which is damaged. Therefore, I recommend using simple drag and drop to do backups.
              CT
            • #2435914
              As by my understanding, if you create a recovery/rescue disk using the SAME software that was used to make the backup, then this disk will also contain a copy of the same software, that can be used to restore the system image (stored usually on a separate device, like an external hard drive), so, this should put you on the safe side as long as you restore on the SAME machine.
              Due to the licensing limitations, even a different but identical machine will not work, because the OS is “tightly attached” to that specific machine (motherboard, a.s.o.).
              Also by my understanding, the Windows standard software installation pack does contain a minimum set of drivers necessary for basically operating the standard devices, like mouse, monitor, keyboard, CD/DVD drive and even a hard disk of any model, or at most, it should be able to automatically download a set of the necessary drivers during the installation process.
              Otherwise it would be impossible to install an OS at all on a brand new and empty machine, with an empty hard disk.
              After the OS installation is complete, the drivers could or should be adjusted or replaced as necessary.
              Regarding the restore points taken by Windows, I would even not expect from it to be able to recover a completely messed up OS … that would be too much to ask,
              but, maybe just to regain a correct set of Registry settings, if the OS system files themselves are still correct and in place (like, for example, for  the case that some other software was installed that makes things to not work properly and you want to revert to the point prior to that installation).
              Well … one that wants to use Windows, has no way out but to slowly become a maintenance engineer for the OS … you cannot choose to remain a “simple user” …
            • #2435919
              Correct. Win7 install disk does in fact contain many drivers. Rarely all that it needs though. I have had instances when it did in fact install all that it required. The most important one is the network driver. If the install does not have it, you will not be able to go online and are completely disconnected. Sadly, that is often the one that does not get installed in the OS process.
              Another point, my advice is to accept those initial drivers and install only the ones the install did not. Then, get those missing drivers ONLY from the OEM. Updating drivers is a common mistake that often leads to serious problems. My advice is that drivers should never be updated just because you can find a more up to date one. ONLY update drivers when and if there is a specific problem that specifically points to a driver. And then only that driver should be updated. Most machines go to the grave yard after living a long life without ever having had a driver update.
              You are correct also that Restore points will not fix a completely botched OS. However, in many if not most it can. Lots of people try other ways to solve their problem BEFORE the try restore and then it is too late. Restore should be 1st solution in many cases.
              As to recovering a backup. The most important use of a backup is being able to use it to restore data to a new hard drive or even a replacemnt computer. There is nothing sorrier than a person who has devotedly done backups and then comes to a fork in the road and the backup cannot be used to restore.
              CT
            • #2435921
              In my opinion, the most important point of restoring a backup is to restore a system backup, aka to “save” your OS at its most recent state, which is what we try to achieve through this thread.
              Regarding the data files, maybe a simple copy to a different device is the best as it already does the work,  you can put them back to any computer, be it the same one or a different one.
              Only the OS is the problem …
            • #2435925
              My comments refer to data backup, not OS. I have been servijng 100s of Win7 machines for many years. I have a firm policy of making a system image every time I re-build or install a system. I do it AFTER all the updates I want to allow, all drivers, and activation. I will also install stable (not dynamic apps), then create an image. That image has proven very useful so many times I cannot count. I use the in-built Win7 software to build it and store in on a set of DVD -R’s — usually from 1 to 4.
              DVD storage of system images has gotten a bad rap from people using +R DVD’s. Plus R is just not reliable Minus R is and I have done this hndreds of tiems.
              CT
            • #2436042
              I think that “Canadian Tech (CT)” is mixing his ‘-‘ and ‘+’ here in this comment #2435925 : “Plus R is just not reliable Minus R is and I have done this hndreds of tiems”.
              See the sub-thread at https://www.askwoody.com/forums/topic/canadian-tech-how-to-rebuild-a-win7-system-with-minimal-snooping/#post-2006766 above, where another Anonymous (not me) quotes the following from CT’s original article: “I emphasize the need for PLUS R DVD blanks. Do not use the more common MINUS R DVD blanks.”
              To avoid further confusion, maybe CT can clarify?
              HTH.
            • #2508895
              Just re-read this and realized I made a critical error. Sorry!!
              DVD -R is a different technology designed for video where minor bit errors do not matter. DVD+R is a much more precise and reliable recording system.
              Do NOT use -R DVD’s for backups of any kind. System Images made on -R will be unreliable.
              CT
            • #2435934
              In order to do a service pack would need a digital signature from Microsoft in order to ensure that it was installable.  No one outside of Microsoft can do that as only they have the Microsoft code signing key.
              When I said the shell – I mean taking a hard drive out of a computer and moving to another computer.  Windows 7, 8, 10 and 11 now pretty easily find the needed drivers for the devices in the computer all by themselves.
            • #2435935
              “but, logically, I have never understood why exactly you can’t just take your OS hard drive and plug it into a different machine,”
              You can.  Once you boot it will have to go online to Microsoft update and find the drivers, on rare occasion you have to go to Dell, HP, etc and find a driver, but pretty much you can move a hard drive to a different machine and it boots just fine.
            • #2436064
              Do you mean that I can plug an OS hard disk from one machine to another and have it continue to work as the OS hard disk on the new machine (aka, a transfer of the OS from one machine to another) ?
              If such a thing could work, then we don’t need any system restore at all.
            • #2436386
              In theory, yes. In practice the systems need to be very similar.
              Basic system restore will overwrite your existing system with data from the backup.
              System restore to bare metal is designed to cover all eventualities – including older non-UEFI boot machines.
      • #2435784
        I’ll put it on the todo list but I’ll be honest it won’t be until later on after my busy season is over.
    • #2435696
      3rd party backup software let you restore to a different machine.
      You can use the same Windows key after the old Windows is wiped from the old machine.
      Example : https://www.easeus.com/backup-utility/restore-image-to-a-different-computer.html#:~:text=So%20can%20you%20create%20and,a%20new%20computer%20is%20possible.
    • #2435815
      Only if it’s a retail license. Not allowed for OEM.
    Viewing 30 reply threads
    Reply To: Canadian Tech: How to rebuild a Win7 system with minimal snooping
