I’ve been looking over the MS dox in re HTML help and find it tedious, and the work involved even more tedious.
Do you have a favorite tool that makes this an easier job?
Home » Forums » AskWoody support » Productivity software by function » MS Access and database help » Building Help? (AXP 10.2627.2625)
Take a look at http://www.helpware.net/ and see if anything there looks like a worksaver. I haven’t built help files with the new HTML help, so I can’t speak to the issue. All my experience was with the equally tedious earlier versions of the help compiler.
You might try HelpScribble. You can download a fully functioning demo version at http://www.helpscribble.com/ and the registered version is only $99. It is really cool, I hated trying to wade through the directions for creating a help file using Microsoft tools and when I got this I looked through the documentation and then created a help file on my own within minutes!
The program will create regular compiled help AND HTML help files as well.
Hope that helps!
Bob Larson
Notifications
