• Alittle bit of VBA help Please
    I am working on building an application. And in the application I’ve constructed a Customer Order Form (frmCustOrdr). An area of this form that I would like to improve is and I believe that I will have to use VBA to accomplish what I want to do. VBA is like ancient Greek to me.
    I have a Customers Table (tblCust)and Ship to Customer Table (tblCustAddrShip)and also a Customer Orders Table (tblCustOrdr). On the Customer Orders Table I have two Lookup Fields, the first is the Customer (CustID) and the second is the Customer Ship To (CustShipID). These fields work fine except for I have only 36 customers and 917 ship to customers. What I and trying to do is, once the CustID is populated and I goto the CustShipID and open the Lookup I would like to see listed those Ship to Addresses that are actual Ship to addresses of the CustID.
    Any help with this endeavor would be appriciate.
    • #514141
      I’m assuming your tblCust and tblCustAddrShip have a common field such as CustID with a one to many relationship. And that you are using a combo drop down box to select your ship-to address. In the properties for that ship-to combo box, in the Row Source ad hoc query insert the criteria for the CustID field to be the CustID of the tblCust. Maybe there is a better way to say this. Maybe someone else has another idea.
      • #514200
        Thank you kindly for the reply. After post the question I was looking thru one of my books. Found the answer there.
        Thank Agian
    Reply To: Alittle bit of VBA help Please
