• Adjust Edge default volume when playing videos?
    Home » Forums » AskWoody support » Questions: Browsers and desktop software » Internet Explorer and Edge » Adjust Edge default volume when playing videos?
    I like to keep my system volume control on 100%. Windows Media Player has it’s own volume control that remains at the setting last used. This works very well. If I need to tweak the volume up or down in WMP, it’s easily done.
    MS Edge, on the other hand, blasts any video you open at 100%. Including those stupid self-playing video advertisements we all hate.
    Is there any way I could set Edge to open all videos at 30% and then increase volume from there if needed? (Without having to constantly change the system volume.)
    Thanks for your help and time.
    • #1571885
      Is there any way … Without having to constantly change the system volume
      Sounds like you might have a subwoofer? While you’re waiting for a software solution, have a look at a physical desktop controller, something like this. I use one which came with a cheap sound system, and almost never need to tweak sound software.
      Lugh.
    • #1571999
      Try right clicking on the speaker icon in the system tray and click on “open volume mixer” You should see a couple of volume controls. See of one is set too loud.
      Jerry
    Reply To: Adjust Edge default volume when playing videos?
