Hi. It appears to me that all spreadsheets have a bottom right-hand corner. I can go there by keying Ctrl-End. However, if I delete a row from the middle of the spreadsheet then the bottom right-hand corner doesn’t change. It is still the same cell as before.
This matters quite a lot when uploading a spreadsheet into MS SQL Server using DTS. The upload proceeds to load every row up to and including the one that holds the bottom right-hand corner. Except that this row is now blank because I have deleted a row some way above it. My database table won’t allow nulls so the blank row causes the upload to abort.
Is there any way to force Excel into accepting a specified cell as the bottom right-hand corner?
Thanks in anticipation
