A Windows expert I know (thanks again, SB!) claims she found out why she couldn’t get the MS12-034 .NET patch installed on her computer. It kept dying
[See the full post at: A solution to the MS12-034 0x8007F0F4 problem?]
Home » Forums » Newsletter and Homepage topics » A solution to the MS12-034 0x8007F0F4 problem?
- This topic has 3 replies, 2 voices, and was last updated 12 years, 8 months ago by
Uli Spalthoff.
AuthorTopicViewing 2 reply threadsAuthorReplies-
John Sessoms
Guest -
Rob T.
GuestMay 22, 2012 at 1:04 am #55874This worked for me! Thanks.
I have CapsLock remapped to a control (ctrl) key on all my machines. The patch install was failing.
I found I was able to reduce the number of reboots by deleting the registry key and then installing the patch without rebooting. Then I put the ScanCode Map entry back. Finally after all three steps I rebooted.
Uli Spalthoff
GuestJuly 5, 2012 at 7:20 pm #55875Thanks for the solution. Finally I found your hint!
Had the same issue with installing security update 2681578 for Windows XP. I had long time ago re-programmed the caps lock key to not interfere with my typing.
Your solution worked. However not from the command line, but I deleted the Scanning Map key using regedit (after backing up the registry, of course …) . Afterwards the installation went through.
Ouff!
Viewing 2 reply threads - This topic has 3 replies, 2 voices, and was last updated 12 years, 8 months ago by
March 2025 updates are out
41 minutes ago -
Windows 11 Insider Preview build 26120.3380 released to DEV and BETA
4 hours, 15 minutes ago -
Update Firefox to prevent add-ons issues from root certificate expiration
11 hours, 24 minutes ago -
Latest Firefox requires Password on start up
Gordski
5 hours, 58 minutes ago -
Resolved : AutoCAD 2022 might not open after updating to 24H2
Missing api-ms-win-core-libraryloader-11-2-1.dll
IreneLinda
1 hour, 51 minutes ago -
How Much Daylight have YOU Saved?
1 hour, 58 minutes ago -
A brief history of Windows Settings
Simon Bisson
15 hours, 56 minutes ago -
Thunderbolt is not just for monitors
Ben Myers
4 hours, 45 minutes ago -
Password Generators — Your first line of defense
2 hours, 13 minutes ago -
AskWoody at the computer museum
38 seconds ago -
Planning for the unexpected
39 minutes ago -
Which printer type is the better one to buy?
Bob99
Upgrading the web server
New Windows 11 24H2 Setup – Initial Win Update prevention settings?
Creating a Google account
DavidofIN
Undocumented “backdoor” found in Bluetooth chip used by a billion devices
2 days ago -
Microsoft Considering AI Models to Replace OpenAI’s in Copilot
2 days, 11 hours ago -
AI *emergent misalignment*
2 days, 12 hours ago -
Windows 11 Disk Encryption/ Bitlocker/ Recovery Key
20 hours, 53 minutes ago -
Trouble signing out and restarting
Tech Hiker
4 hours, 10 minutes ago -
Windows 7 MSE Manual Updating
2 days, 21 hours ago -
Problem running LMC 22 flash drive
Charlie
Outlook Email Problem
Lil88reb
“Microsoft 365 Office All-in-One For Dummies, 3rd Edition FREE
2 days, 3 hours ago -
Cant use Office 2013 – Getting error message about Office 2013
SAAR
2 days, 20 hours ago -
Nearly 1 million Windows devices targeted in advanced “malvertising” spree
Windows 11 Insider Preview build 27808 released to Canary
3 days, 21 hours ago -
Windows 11 Insider Preview Build 22635.5025 (23H2) released to BETA
Sysprep issue
Evit
